Stat value not updating
New to Grafana here.
I’m just experimenting with Grafana right now, I managed to read my data from InfluxDB. I’m just trying to throw it up on a singlestat. I got it to work, but it doesn’t update/change if or when my data changes unless I refresh the page. Is this right? How do I get it to update live?
If I understand your question correctly then all you need to do is click the arrow next to the refresh icon in the top right. Then you can set it to automatically refresh at specific intervals. It’s probably set to “Off” right now.
Yes! That did it. It was set to default of 15s and newb user me was being impatient. Thanks!
@dczysz
The refresh options start from a minimum of 5sec.
Can I configure it to be lower… 1sec?
