Standalone Service Status dashboards using new Grafana 8.0 status history/timeline features?
I noticed in Grafana 8.0 there’s some new features - specifically state history and state timeline. I’m still a bit confused as to the differences between them, and when you’d use one over the other.
However, has anybody considered creating a service status dashboard using these? (i.e. as an alternative to something like Catchet). How did/would you do it?
Also - what’s the best way of serving a standalone Grafana dashboard like this at say, status.example.org, that doesn’t require access to the main Grafana setup?
Hi @victorhooi! Welcome back to the forum :+1:
Question 1:
Check out this public dashboard and let me know if this helps clarifies the differences between the two:
https://play.grafana.org/d/YI95GyqMz/1-new-features-in-v8-0?orgId=1
Question 2:
I think what you want is very much possible: creating a service status dashboard using these panels. Are you actively trying to implement htis in Grafana?
Question 3:
I think that embedding a dashboard inside an iframe is your best solution here:
