Stacked bar chart for azure finops
Hi
Im doing some finops analytics from Azure !
Im using infinity datasource !
I want to show price by day with stacked value of each service
exemple:
For the moment my result look like this !
I have the total of the day but no stacked values !
Im using those transformations :
  "transformations": [
      "id": "extractFields",
      "options": {
        "replace": true,
        "source": "A"
      "id": "organize",
      "options": {
        "excludeByName": {},
        "indexByName": {
          "0": 0,
          "1": 1,
          "2": 2,
          "3": 3
        "renameByName": {
          "0": "Cost",
          "1": "Date",
          "2": "ServiceName",
          "3": "Currency"
        "includeByName": {}
      "id": "groupBy",
      "options": {
        "fields": {
          "Cost": {
            "aggregations": [
              "sum"
            "operation": "aggregate"
          "Date": {
            "aggregations": [],
            "operation": "groupby"
          "ServiceName": {
            "aggregations": [
              "allValues"
one data row look like this :
[1.2,20241001,"VM","EUR"]
I also want to make the date look like this
2024-10-09 insted of 20241009
Thanks :smiley:
In case you want the ful pannel json
  "datasource": {
    "default": false,
    "uid": "ee0fp0b2eyqdcb",
    "type": "yesoreyeram-infinity-datasource"
  "fieldConfig": {
    "defaults": {
      "custom": {
        "lineWidth": 1,
        "fillOpacity": 80,
        "gradientMode": "none",
        "axisPlacement": "auto",
        "axisLabel": "",
        "axisColorMode": "text",
        "axisBorderShow": false,
        "scaleDistribution": {
          "type": "linear"
        "axisCenteredZero": false,
        "hideFrom": {
          "tooltip": false,
          "viz": false,
          "legend": false
        "thresholdsStyle": {
          "mode": "line"
      "color": {
        "mode": "thresholds"
      "mappings": [],
      "thresholds": {
        "mode": "percentage",
        "steps": [
            "color": "green",
            "value": null
    "overrides": []
  "gridPos": {
    "h": 9,
    "w": 24,
    "x": 0,
    "y": 1
  "id": 5,
  "options": {
    "orientation": "vertical",
    "xTickLabelRotation": 0,
    "xTickLabelSpacing": 0,
    "showValue": "always",
    "stacking": "none",
    "groupWidth": 0.7,
    "barWidth": 0.75,
    "barRadius": 0,
    "fullHighlight": false,
    "tooltip": {
      "mode": "multi",
      "sort": "none"
    "legend": {
      "showLegend": true,
      "displayMode": "list",
      "placement": "bottom",
      "calcs": []
    "colorByField": "Cost",
    "xField": "Date"
  "pluginVersion": "11.2.2",
  "targets": [
      "datasource": {
        "type": "yesoreyeram-infinity-datasource",
      "columns": [],
      "filters": [],
      "format": "table",
      "global_query_id": "",
      "parser": "backend",
      "refId": "A",
      "root_selector": "properties.rows[*]",
      "source": "url",
      "type": "json",
      "url": "https://management.azure.com/subscriptions/e8134c01-8d85-4322-b67b-0d4259dd8fdc/providers/Microsoft.CostManagement/query?api-version=2023-11-01",
      "url_options": {
        "body_content_type": "application/json",
        "body_type": "raw",
        "data": "{\n  \"type\": \"Usage\",\n  \"timeframe\": \"Custom\",\n  \"timePeriod\": {\n    \"from\": \"$from\",\n    \"to\": \"$to\"\n  },\n  \"dataset\": {\n    \"granularity\": \"Daily\",\n    \"aggregation\": {\n      \"totalCost\": {\n        \"name\": \"Cost\",\n        \"function\": \"Sum\"\n      }\n    },\n    \"grouping\": [\n      {\n        \"type\": \"Dimension\",\n        \"name\": \"ServiceName\"\n      }\n    ]\n  }\n}",
        "method": "POST"
  "title": "Usage Cost - Applied Duration",
      "options": {
        "replace": true,
        "source": "A"
      "id": "organize",
      "options": {
        "indexByName": {
          "0": 0,
          "1": 1,
          "2": 2,
          "3": 3
        "renameByName": {
          "0": "Cost",
          "1": "Date",
          "2": "ServiceName",
          "3": "Currency"
        "includeByName": {}
      "id": "groupBy",
      "options": {
        "fields": {
          "Cost": {
            "aggregations": [
              "sum"
          "Date": {
            "aggregations": [],
          "ServiceName": {
            "aggregations": [
              "allValues"
  "type": "barchart"
Choose time series as Format and also Stacking Normal
I just tried but it dont seem to work !
My data tranform look like this
please post raw json data coming from your rest api or endpoint
                      "rows": [
                          9.25597434792304,
                          20241001,
                          "Application Gateway",
                          "EUR"
                          0,
                          20241001,
                          "Automation",
                          "EUR"
                          2.88339078296502,
                          20241001,
                          "NAT Gateway",
                          "EUR"
                          11.2886013719307,
                          20241002,
                          "EUR"
                          0,
                          20241002,
                          "Automation",
                          "EUR"
                          0.384953682024142,
                          20241002,
                          "Azure DNS",
                          "EUR"
Thats an example of the source (i cant put all the json there is private data)
It correspond to the array that i get from parsing my output
so that is not a valid json. please vet data
  "request": {
    "url": "api/ds/query?ds_type=yesoreyeram-infinity-datasource&requestId=Q138",
    "method": "POST",
    "data": {
      "queries": [
          "datasource": {
          "columns": [],
          "filters": [],
          "format": "timeseries",
          "refId": "A",
          "source": "url",
          "type": "json",
          "url": "https://management.azure.com/subscriptions//providers/Microsoft.CostManagement/query?api-version=2023-11-01",
          "url_options": {
            "body_type": "raw",
            "data": "{\n  \"type\": \"Usage\",\n  \"timeframe\": \"Custom\",\n  \"timePeriod\": {\n    \"from\": \"2024-10-01\",\n    \"to\": \"2024-10-02\"\n  },\n  \"dataset\": {\n    \"granularity\": \"Daily\",\n    \"aggregation\": {\n      \"totalCost\": {\n        \"name\": \"Cost\",\n        \"function\": \"Sum\"\n      }\n    },\n    \"grouping\": [\n      {\n        \"type\": \"Dimension\",\n        \"name\": \"ServiceName\"\n      }\n    ]\n  }\n}",
            "method": "POST",
            "body_graphql_query": "",
            "body_graphql_variables": ""
          "computed_columns": [],
          "filterExpression": "",
          "summarizeExpression": "",
          "datasourceId": 3,
          "intervalMs": 30000,
          "maxDataPoints": 719
      "from": "1728561381961",
      "to": "1728582981961"
    "hideFromInspector": false
  "response": {
    "results": {
      "A": {
        "status": 200,
        "frames": [
            "schema": {
              "name": "A",
              "refId": "A",
              "meta": {
                "typeVersion": [
                  0,
                  0
                "custom": {
                  "data": {
                    "eTag": null,
                    "id": "subscriptions//providers/Microsoft.CostManagement/query/",
                    "location": null,
                    "name": "",
                    "properties": {
                      "columns": [
                          "name": "Cost",
                          "type": "Number"
                          "name": "UsageDate",
                          "type": "Number"
                          "name": "ServiceName",
                          "type": "String"
                          "name": "Currency",
                          "type": "String"
                      "nextLink": null,
                      "rows": [
                          9.25597434792304,
                          20241001,
                          "EUR"
                          0,
                          20241001,
                          "Automation",
                          "EUR"
                          16.2412401575407,
                          20241001,
                          "Azure App Service",
                          "EUR"
                          6.23292884968432,
                          20241001,
                          "Azure Bastion",
                          "EUR"
                          0.430322005180519,
                          20241001,
                          "Azure DNS",
                          "EUR"
                          0.00000895535754264989,
                          20241001,
                          "Azure Data Factory v2",
                          "EUR"
                          5.95997228413135,
                          20241001,
                          "Azure Database for MySQL",
                          "EUR"
                          0.983587140684334,
                          20241001,
                          "Azure Database for PostgreSQL",
                          "EUR"
                          10.601987800492,
                          20241001,
                          "Azure DevOps",
                          "EUR"
                          24.5640844304826,
                          20241001,
                          "Azure Front Door Service",
                          "EUR"
                          4.87307059365934,
                          20241001,
                          "Backup",
                          "EUR"
                          0.00722409149740619,
                          20241001,
                          "Bandwidth",
                          "EUR"
                          1.19393781901222,
                          20241001,
                          "Container Registry",
                          "EUR"
                          0,
                          20241001,
                          "Insight and Analytics",
                          "EUR"
                          1.61199901664664,
                          20241001,
                          "Load Balancer",
                          "EUR"
                          0,
                          20241001,
                          "Log Analytics",
                          "EUR"
                          0,
                          20241001,
                          "Microsoft Defender for Cloud",
                          "EUR"
                          2.88339078296502,
                          20241001,
                          "NAT Gateway",
                          "EUR"
                          3.71826445170823,
                          20241001,
                          "Redis Cache",
                          "EUR"
                          6.30446578713115,
                          20241001,
                          "Storage",
                          "EUR"
                          14.9138982492276,
                          20241001,
                          "Virtual Machines",
                          "EUR"
                          5.0938043712376,
                          20241001,
                          "Virtual Network",
                          "EUR"
                          11.2886013719307,
                          20241002,
                          "EUR"
                          0,
                          20241002,
                          "Automation",
                          "EUR"
                          16.2412401575407,
                          20241002,
                          "EUR"
                          6.23292884968432,
                          20241002,
                          "Azure Bastion",
                          "EUR"
                          0.384953682024142,
                          20241002,
                          "Azure DNS",
                          "EUR"
                          5.52003252094759,
                          20241002,
                          "EUR"
                          0.983587140684334,
                          20241002,
                          "EUR"
                          10.601987800492,
                          20241002,
                          "Azure DevOps",
                          "EUR"
                          23.4248006876139,
                          20241002,
                          "EUR"
                          4.86812372899352,
                          20241002,
                          "Backup",
                          "EUR"
                          0.0082495189270704,
                          20241002,
                          "Bandwidth",
                          "EUR"
                          1.19393781901222,
                          20241002,
                          "EUR"
                          0,
                          20241002,
                          "EUR"
                          1.611990853039,
                          20241002,
                          "Load Balancer",
                          "EUR"
                          0,
                          20241002,
                          "Log Analytics",
                          "EUR"
                          0,
                          20241002,
                          "EUR"
                          3.01820150195504,
                          20241002,
                          "NAT Gateway",
                          "EUR"
                          3.71826445170823,
                          20241002,
                          "Redis Cache",
                          "EUR"
                          6.34559069977164,
                          20241002,
                          "Storage",
                          "EUR"
                          14.9934205174406,
                          20241002,
                          "Virtual Machines",
                          "EUR"
                          5.18118969008666,
                          20241002,
                          "Virtual Network",
                          "EUR"
                    "sku": null,
                    "type": "Microsoft.CostManagement/query"
                  "duration": 830837230,
                  "error": "",
                  "query": {
                    "alias": "",
                    "columns": [],
                    "csv_options": {
                      "columns": "",
                      "comment": "",
                      "delimiter": "",
                      "relax_column_count": false,
                      "skip_empty_lines": false,
                      "skip_lines_with_error": false
                    "data": "",
                    "dataOverrides": null,
                    "expression": "",
                    "filters": [],
                    "groq": "",
                    "json_options": {
                      "columnar": false,
                      "root_is_not_array": false
                    "query_mode": "",
                    "refId": "A",
                    "seriesCount": 0,
                    "source": "url",
                    "summarizeAlias": "",
                    "summarizeBy": "",
                    "type": "json",
                    "uql": "",
                    "url_options": {
                      "body_form": null,
                      "body_graphql_variables": "",
                      "body_type": "raw",
                      "headers": null,
                      "method": "POST",
                      "params": null
                  "responseCodeFromServer": 200
                "executedQueryString": "###############\n## URL\n###############\n\nhttps://management.azure.com/subscriptions//providers/Microsoft.CostManagement/query?api-version=2023-11-01\n\n###############\n## Curl Command\n###############\n\ncurl -X 'POST' -d '{\n  \"type\": \"Usage\",\n  \"timeframe\": \"Custom\",\n  \"timePeriod\": {\n    \"from\": \"2024-10-01\",\n    \"to\": \"2024-10-02\"\n  },\n  \"dataset\": {\n    \"granularity\": \"Daily\",\n    \"aggregation\": {\n      \"totalCost\": {\n        \"name\": \"Cost\",\n        \"function\": \"Sum\"\n      }\n    },\n    \"grouping\": [\n      {\n        \"type\": \"Dimension\",\n        \"name\": \"ServiceName\"\n      }\n    ]\n  }\n}' -H 'Accept: application/json;q=0.9,text/plain' -H 'Content-Type: application/json' 'https://management.azure.com/subscriptions//providers/Microsoft.CostManagement/query?api-version=2023-11-01'\n###############\n> Authentication steps not included for OAuth authentication"
              "fields": [
                  "name": "A",
                  "type": "string",
                  "typeInfo": {
                    "frame": "string",
                    "nullable": true
            "data": {
              "values": [
                  "[9.25597434792304,20241001,\"Application Gateway\",\"EUR\"]",
                  "[0,20241001,\"Automation\",\"EUR\"]",
                  "[16.2412401575407,20241001,\"Azure App Service\",\"EUR\"]",
                  "[6.23292884968432,20241001,\"Azure Bastion\",\"EUR\"]",
                  "[0.430322005180519,20241001,\"Azure DNS\",\"EUR\"]",
                  "[0.00000895535754264989,20241001,\"Azure Data Factory v2\",\"EUR\"]",
                  "[5.95997228413135,20241001,\"Azure Database for MySQL\",\"EUR\"]",
                  "[0.983587140684334,20241001,\"Azure Database for PostgreSQL\",\"EUR\"]",
                  "[10.601987800492,20241001,\"Azure DevOps\",\"EUR\"]",
                  "[24.5640844304826,20241001,\"Azure Front Door Service\",\"EUR\"]",
                  "[4.87307059365934,20241001,\"Backup\",\"EUR\"]",
                  "[0.00722409149740619,20241001,\"Bandwidth\",\"EUR\"]",
                  "[1.19393781901222,20241001,\"Container Registry\",\"EUR\"]",
                  "[0,20241001,\"Insight and Analytics\",\"EUR\"]",
                  "[1.61199901664664,20241001,\"Load Balancer\",\"EUR\"]",
                  "[0,20241001,\"Log Analytics\",\"EUR\"]",
                  "[0,20241001,\"Microsoft Defender for Cloud\",\"EUR\"]",
                  "[2.88339078296502,20241001,\"NAT Gateway\",\"EUR\"]",
                  "[3.71826445170823,20241001,\"Redis Cache\",\"EUR\"]",
                  "[6.30446578713115,20241001,\"Storage\",\"EUR\"]",
                  "[14.9138982492276,20241001,\"Virtual Machines\",\"EUR\"]",
                  "[5.0938043712376,20241001,\"Virtual Network\",\"EUR\"]",
                  "[11.2886013719307,20241002,\"Application Gateway\",\"EUR\"]",
                  "[0,20241002,\"Automation\",\"EUR\"]",
                  "[16.2412401575407,20241002,\"Azure App Service\",\"EUR\"]",
                  "[6.23292884968432,20241002,\"Azure Bastion\",\"EUR\"]",
                  "[0.384953682024142,20241002,\"Azure DNS\",\"EUR\"]",
                  "[5.52003252094759,20241002,\"Azure Database for MySQL\",\"EUR\"]",
                  "[0.983587140684334,20241002,\"Azure Database for PostgreSQL\",\"EUR\"]",
                  "[10.601987800492,20241002,\"Azure DevOps\",\"EUR\"]",
                  "[23.4248006876139,20241002,\"Azure Front Door Service\",\"EUR\"]",
                  "[4.86812372899352,20241002,\"Backup\",\"EUR\"]",
                  "[0.0082495189270704,20241002,\"Bandwidth\",\"EUR\"]",
                  "[1.19393781901222,20241002,\"Container Registry\",\"EUR\"]",
                  "[0,20241002,\"Insight and Analytics\",\"EUR\"]",
                  "[1.611990853039,20241002,\"Load Balancer\",\"EUR\"]",
                  "[0,20241002,\"Log Analytics\",\"EUR\"]",
                  "[0,20241002,\"Microsoft Defender for Cloud\",\"EUR\"]",
                  "[3.01820150195504,20241002,\"NAT Gateway\",\"EUR\"]",
                  "[3.71826445170823,20241002,\"Redis Cache\",\"EUR\"]",
                  "[6.34559069977164,20241002,\"Storage\",\"EUR\"]",
                  "[14.9934205174406,20241002,\"Virtual Machines\",\"EUR\"]",
                  "[5.18118969008666,20241002,\"Virtual Network\",\"EUR\"]"
        "refId": "A"
one possible way is using jsonata
https://try.jsonata.org/xWHG3dJTH
I just tryied like you :
Json data:
    9.25597434792304,
    20241001,
    "EUR"
    0,
    20241001,
    "Automation",
    "EUR"
    16.2412401575407,
    20241001,
    "EUR"
    6.23292884968432,
    20241001,
    "Azure Bastion",
    "EUR"
    0.430322005180519,
    20241001,
    "Azure DNS",
    "EUR"
    20241001,
    "EUR"
    5.95997228413135,
    20241001,
    "EUR"
    0.983587140684334,
    20241001,
    "EUR"
    10.601987800492,
    20241001,
    "Azure DevOps",
    "EUR"
    24.5640844304826,
    20241001,
    "EUR"
    4.87307059365934,
    20241001,
    "Backup",
    "EUR"
    20241001,
    "Bandwidth",
    "EUR"
    1.19393781901222,
    20241001,
    "EUR"
    0,
    20241001,
    "EUR"
    1.61199901664664,
    20241001,
    "Load Balancer",
    "EUR"
    0,
    20241001,
    "Log Analytics",
    "EUR"
    0,
    20241001,
    "EUR"
    2.88339078296502,
    20241001,
    "NAT Gateway",
    "EUR"
    3.71826445170823,
    20241001,
    "Redis Cache",
    "EUR"
    6.30446578713115,
    20241001,
    "Storage",
    "EUR"
    14.9138982492276,
    20241001,
    "Virtual Machines",
    "EUR"
    5.0938043712376,
    20241001,
    "Virtual Network",
    "EUR"
    11.2886013719307,
    20241002,
    "EUR"
    0,
    20241002,
    "Automation",
    "EUR"
    16.2412401575407,
    20241002,
    "EUR"
    6.23292884968432,
    20241002,
    "Azure Bastion",
    "EUR"
    0.384953682024142,
    20241002,
    "Azure DNS",
    "EUR"
    5.52003252094759,
    20241002,
    "EUR"
    0.983587140684334,
    20241002,
    "EUR"
    10.601987800492,
    20241002,
    "Azure DevOps",
    "EUR"
    23.4248006876139,
    20241002,
    "EUR"
    4.86812372899352,
    20241002,
    "Backup",
    "EUR"
    0.0082495189270704,
    20241002,
    "Bandwidth",
    "EUR"
    1.19393781901222,
    20241002,
    "EUR"
    0,
    20241002,
    "EUR"
    1.611990853039,
    20241002,
    "Load Balancer",
    "EUR"
    0,
    20241002,
    "Log Analytics",
    "EUR"
    0,
    20241002,
    "EUR"
    3.01820150195504,
    20241002,
    "NAT Gateway",
    "EUR"
    3.71826445170823,
    20241002,
    "Redis Cache",
    "EUR"
    6.34559069977164,
    20241002,
    "Storage",
    "EUR"
    14.9934205174406,
    20241002,
    "Virtual Machines",
    "EUR"
    5.18118969008666,
    20241002,
    "Virtual Network",
    "EUR"
UQL :
parse-json
| jsonata "$map($, function($v, $i, $a) {{'value': $v[0],'date': $substring($string($v[1]),0,4) & "-" & $substring($string($v[1]),4,2) & "-" & $substring($string($v[1]),6,2),'metric': $v[2],'currency': $v[3]}})"
| project "date", "value", "metric"
And i have the error : No data in response
I just tried like you
UQL
parse-json
Data
    9.25597434792304,
    20241001,
    "EUR"
    0,
    20241001,
    "Automation",
    "EUR"
    16.2412401575407,
    20241001,
    "EUR"
    6.23292884968432,
    20241001,
    "Azure Bastion",
    "EUR"
    0.430322005180519,
    20241001,
    "Azure DNS",
    "EUR"
    20241001,
    "EUR"
    5.95997228413135,
    20241001,
    "EUR"
    0.983587140684334,
    20241001,
    "EUR"
    10.601987800492,
    20241001,
    "Azure DevOps",
    "EUR"
    24.5640844304826,
    20241001,
    "EUR"
    4.87307059365934,
    20241001,
    "Backup",
    "EUR"
    20241001,
    "Bandwidth",
    "EUR"
    1.19393781901222,
    20241001,
    "EUR"
    0,
    20241001,
    "EUR"
    1.61199901664664,
    20241001,
    "Load Balancer",
    "EUR"
    0,
    20241001,
    "Log Analytics",
    "EUR"
    0,
    20241001,
    "EUR"
    2.88339078296502,
    20241001,
    "NAT Gateway",
    "EUR"
    3.71826445170823,
    20241001,
    "Redis Cache",
    "EUR"
    6.30446578713115,
    20241001,
    "Storage",
    "EUR"
    14.9138982492276,
    20241001,
    "Virtual Machines",
    "EUR"
    5.0938043712376,
    20241001,
    "Virtual Network",
    "EUR"
    11.2886013719307,
    20241002,
    "EUR"
    0,
    20241002,
    "Automation",
    "EUR"
    16.2412401575407,
    20241002,
    "EUR"
    6.23292884968432,
    20241002,
    "Azure Bastion",
    "EUR"
    0.384953682024142,
    20241002,
    "Azure DNS",
    "EUR"
    5.52003252094759,
    20241002,
    "EUR"
    0.983587140684334,
    20241002,
    "EUR"
    10.601987800492,
    20241002,
    "Azure DevOps",
    "EUR"
    23.4248006876139,
    20241002,
    "EUR"
    4.86812372899352,
    20241002,
    "Backup",
    "EUR"
    0.0082495189270704,
    20241002,
    "Bandwidth",
    "EUR"
    1.19393781901222,
    20241002,
    "EUR"
    0,
    20241002,
    "EUR"
    1.611990853039,
    20241002,
    "Load Balancer",
    "EUR"
    0,
    20241002,
    "Log Analytics",
    "EUR"
    0,
    20241002,
    "EUR"
    3.01820150195504,
    20241002,
    "NAT Gateway",
    "EUR"
    3.71826445170823,
    20241002,
    "Redis Cache",
    "EUR"
    6.34559069977164,
    20241002,
    "Storage",
    "EUR"
    14.9934205174406,
    20241002,
    "Virtual Machines",
    "EUR"
    5.18118969008666,
    20241002,
    "Virtual Network",
    "EUR"
But i have the error No data in response
What is your data looks like ?
I have an error :
No data in response
Data :
    9.25597434792304,
    20241001,
    "EUR"
    0,
    20241001,
    "Automation",
    "EUR"
    16.2412401575407,
    20241001,
    "EUR"
    6.23292884968432,
    20241001,
    "Azure Bastion",
    "EUR"
    0.430322005180519,
    20241001,
    "Azure DNS",
    "EUR"
    20241001,
    "EUR"
    5.95997228413135,
    20241001,
    "EUR"
    0.983587140684334,
    20241001,
    "EUR"
    10.601987800492,
    20241001,
    "Azure DevOps",
    "EUR"
    24.5640844304826,
    20241001,
    "EUR"
    4.87307059365934,
    20241001,
    "Backup",
    "EUR"
    20241001,
    "Bandwidth",
    "EUR"
    1.19393781901222,
    20241001,
    "EUR"
    0,
    20241001,
    "EUR"
    1.61199901664664,
    20241001,
    "Load Balancer",
    "EUR"
    0,
    20241001,
    "Log Analytics",
    "EUR"
    0,
    20241001,
    "EUR"
    2.88339078296502,
    20241001,
    "NAT Gateway",
    "EUR"
    3.71826445170823,
    20241001,
    "Redis Cache",
    "EUR"
    6.30446578713115,
    20241001,
    "Storage",
    "EUR"
    14.9138982492276,
    20241001,
    "Virtual Machines",
    "EUR"
    5.0938043712376,
    20241001,
    "Virtual Network",
    "EUR"
    11.2886013719307,
    20241002,
    "EUR"
    0,
    20241002,
    "Automation",
    "EUR"
    16.2412401575407,
    20241002,
    "EUR"
    6.23292884968432,
    20241002,
    "Azure Bastion",
    "EUR"
    0.384953682024142,
    20241002,
    "Azure DNS",
    "EUR"
    5.52003252094759,
    20241002,
    "EUR"
    0.983587140684334,
    20241002,
    "EUR"
    10.601987800492,
    20241002,
    "Azure DevOps",
    "EUR"
    23.4248006876139,
    20241002,
    "EUR"
    4.86812372899352,
    20241002,
    "Backup",
    "EUR"
    0.0082495189270704,
    20241002,
    "Bandwidth",
    "EUR"
    1.19393781901222,
    20241002,
    "EUR"
    0,
    20241002,
    "EUR"
    1.611990853039,
    20241002,
    "Load Balancer",
    "EUR"
    0,
    20241002,
    "Log Analytics",
    "EUR"
    0,
    20241002,
    "EUR"
    3.01820150195504,
    20241002,
    "NAT Gateway",
    "EUR"
    3.71826445170823,
    20241002,
    "Redis Cache",
    "EUR"
    6.34559069977164,
    20241002,
    "Storage",
    "EUR"
    14.9934205174406,
    20241002,
    "Virtual Machines",
    "EUR"
    5.18118969008666,
    20241002,
    "Virtual Network",
    "EUR"
UQL :
parse-json
and i tried all formats
And you seem to have a Transform data ? :smile:
i just found this error !
This feature is not available for this type of query yet when not using format “as is”
What format do you use ?
You raw data keeps changing with every post
rows
properties.rows
what does the json data look like from the api or endpoint. and please dont post dashboard json :laughing:
From the query inspector it look like this !
Here i use the properties.rows,
With JSON and Backend Parser
  "request": {
    "url": "api/ds/query?ds_type=yesoreyeram-infinity-datasource&requestId=Q113",
    "method": "POST",
    "data": {
      "queries": [
          "datasource": {
          "columns": [],
          "filters": [],
          "format": "table",
          "refId": "A",
          "source": "url",
          "type": "json",
          "url": "https://management.azure.com/subscriptions/xxxxx/providers/Microsoft.CostManagement/query?api-version=2023-11-01",
          "url_options": {
            "body_type": "raw",
            "method": "POST",
          "datasourceId": 3,
          "intervalMs": 20000,
          "maxDataPoints": 1109
      "from": "1728577546744",
      "to": "1728599146745"
  "response": {
    "results": {
      "A": {
        "status": 200,
        "frames": [
            "schema": {
              "name": "A",
              "refId": "A",
              "meta": {
                "typeVersion": [
                  0,
                  0
                "custom": {
                  "data": {
                    "eTag": null,
                    "id": "subscriptions/xxxx/providers/Microsoft.CostManagement/query/4xxx",
                    "location": null,
                    "name": "4c75b31c-6889-43b1-8325-0593c2fe8484",
                    "properties": {
                      "columns": [
                          "name": "Cost",
                          "type": "Number"
                          "type": "Number"
                          "type": "String"
                          "name": "Currency",
                          "type": "String"
                      "nextLink": null,
                      "rows": [
                          9.25597434792304,
                          20241001,
                          "EUR"
                          0,
                          20241001,
                          "Automation",
                          "EUR"
                          16.2412401575407,
                          20241001,
                          "EUR"
                          6.23292884968432,
                          20241001,
                          "Azure Bastion",
                          "EUR"
                          0.430322005180519,
                          20241001,
                          "Azure DNS",
                          "EUR"
                          20241001,
                          "EUR"
                          5.95997228413135,
                          20241001,
                          "EUR"
                          0.983587140684334,
                          20241001,
                          "EUR"
                          10.601987800492,
                          20241001,
                          "Azure DevOps",
                          "EUR"
                          24.5640844304826,
                          20241001,
                          "EUR"
                          4.87307059365934,
                          20241001,
                          "Backup",
                          "EUR"
                          20241001,
                          "Bandwidth",
                          "EUR"
                          1.19393781901222,
                          20241001,
                          "EUR"
                          0,
                          20241001,
                          "EUR"
                          1.61199901664664,
                          20241001,
                          "Load Balancer",
                          "EUR"
                          0,
                          20241001,
                          "Log Analytics",
                          "EUR"
                          0,
                          20241001,
                          "EUR"
                          2.88339078296502,
                          20241001,
                          "NAT Gateway",
                          "EUR"
                          3.71826445170823,
                          20241001,
                          "Redis Cache",
                          "EUR"
                          6.30446578713115,
                          20241001,
                          "Storage",
                          "EUR"
                          14.9138982492276,
                          20241001,
                          "Virtual Machines",
                          "EUR"
                          5.0938043712376,
                          20241001,
                          "Virtual Network",
                          "EUR"
                          11.2886013719307,
                          20241002,
                          "EUR"
                          0,
                          20241002,
                          "Automation",
                          "EUR"
                          16.2412401575407,
                          20241002,
                          "EUR"
                          6.23292884968432,
                          20241002,
                          "Azure Bastion",
                          "EUR"
                          0.384953682024142,
                          20241002,
                          "Azure DNS",
                          "EUR"
                          5.52003252094759,
                          20241002,
                          "EUR"
                          0.983587140684334,
                          20241002,
                          "EUR"
                          10.601987800492,
                          20241002,
                          "Azure DevOps",
                          "EUR"
                          23.4248006876139,
                          20241002,
                          "EUR"
                          4.86812372899352,
                          20241002,
                          "Backup",
                          "EUR"
                          0.0082495189270704,
                          20241002,
                          "Bandwidth",
                          "EUR"
                          1.19393781901222,
                          20241002,
                          "EUR"
                          0,
                          20241002,
                          "EUR"
                          1.611990853039,
                          20241002,
                          "Load Balancer",
                          "EUR"
                          0,
                          20241002,
                          "Log Analytics",
                          "EUR"
                          0,
                          20241002,
                          "EUR"
                          3.01820150195504,
                          20241002,
                          "NAT Gateway",
                          "EUR"
                          3.71826445170823,
                          20241002,
                          "Redis Cache",
                          "EUR"
                          6.34559069977164,
                          20241002,
                          "Storage",
                          "EUR"
                          14.9934205174406,
                          20241002,
                          "Virtual Machines",
                          "EUR"
                          5.18118969008666,
                          20241002,
                          "Virtual Network",
                          "EUR"
                    "sku": null,
                  "duration": 4268734301,
                  "error": "",
                  "query": {
                    "alias": "",
                    "columns": [],
                    "csv_options": {
                      "columns": "",
                      "comment": "",
                      "delimiter": "",
                    "data": "",
                    "expression": "",
                    "filters": [],
                    "format": "table",
                    "groq": "",
                    "json_options": {
                      "columnar": false,
                    "query_mode": "",
                    "refId": "A",
                    "seriesCount": 0,
                    "source": "url",
                    "summarizeBy": "",
                    "type": "json",
                    "uql": "",
                    "url": "https://management.azure.com/subscriptions/xxxx/providers/Microsoft.CostManagement/query?api-version=2023-11-01",
                    "url_options": {
                      "body_form": null,
                      "body_type": "raw",
                      "headers": null,
                      "method": "POST",
                      "params": null
                "executedQueryString": "###############\n## URL\n###############\n\nhttps://management.azure.com/subscriptions/e8134c01-8d85-4322-b67b-0d4259dd8fdc/providers/Microsoft.CostManagement/query?api-version=2023-11-01\n\n###############\n## Curl Command\n###############\n\ncurl -X 'POST' -d '{\n  \"type\": \"Usage\",\n  \"timeframe\": \"Custom\",\n  \"timePeriod\": {\n    \"from\": \"2024-10-01\",\n    \"to\": \"2024-10-02\"\n  },\n  \"dataset\": {\n    \"granularity\": \"Daily\",\n    \"aggregation\": {\n      \"totalCost\": {\n        \"name\": \"Cost\",\n        \"function\": \"Sum\"\n      }\n    },\n    \"grouping\": [\n      {\n        \"type\": \"Dimension\",\n        \"name\": \"ServiceName\"\n      }\n    ]\n  }\n}' -H 'Accept: application/json;q=0.9,text/plain' -H 'Content-Type: application/json' 'https://management.azure.com/subscriptions/xx/providers/Microsoft.CostManagement/query?api-version=2023-11-01'\n###############\n> Authentication steps not included for OAuth authentication"
              "fields": [
                  "name": "A",
                  "type": "string",
                  "typeInfo": {
                    "frame": "string",
                    "nullable": true
            "data": {
              "values": [
        "refId": "A"
Not from query inspector, from the api
Maybe using another tool like insomnia or postman
Oh okey i didnt understand :
  "id": "subscriptions/xxx/providers/Microsoft.CostManagement/query/xx",
  "name": "xx",
  "type": "Microsoft.CostManagement/query",
  "location": null,
  "sku": null,
  "eTag": null,
  "properties": {
    "nextLink": null,
    "columns": [
        "name": "Cost",
        "type": "Number"
        "type": "Number"
        "type": "String"
        "name": "Currency",
        "type": "String"
    "rows": [
        9.25597434792304,
        20241001,
        "EUR"
        0,
        20241001,
        "Automation",
        "EUR"
        6.23292884968432,
        20241001,
        "Azure Bastion",
        "EUR"
        11.2886013719307,
        20241002,
        "EUR"
        0,
        20241002,
        "Automation",
        "EUR"
        6.23292884968432,
        20241002,
        "Azure Bastion",
        "EUR"
this could be better !
now take that data blob and figure out the jsonata using https://try.jsonata.org/
So i foud this :
$map(properties.rows, function($v) {
    'value': $v[0],
    'date': $substring($string($v[1]), 0, 4) & "-" & $substring($string($v[1]), 4, 2) & "-" & $substring($string($v[1]), 6, 2),
    'metric': $v[2],
    'currency': $v[3]
that is giving me :
    "value": 9.255974347923,
    "date": "2024-10-01",
    "metric": "Application Gateway",
    "currency": "EUR"
    "value": 0,
    "metric": "Automation",
    "currency": "EUR"
    "value": 6.232928849684,
    "metric": "Azure Bastion",
    "currency": "EUR"
    "value": 11.28860137193,
    "date": "2024-10-02",
    "currency": "EUR"
    "value": 0,
    "currency": "EUR"
    "currency": "EUR"
Now : i prepare my querry :
Type JSON, Parser UQL, Source URL, Data Frame : (i tried all)
and my UQL :
parse-json
| jsonata "$map(properties.rows, function($v) {{'value': $v[0],'date': $substring($string($v[1]), 0, 4) & "-" & $substring($string($v[1]), 4, 2) & "-" & $substring($string($v[1]), 6, 2), 'metric': $v[2],'currency': $v[3]}})"
But still no result :confused:
Edit : i have an error : “error applying uql query”
If i use only the parse-json i have my json so my problem is after
maybe & "-" & to & '-' &
