Stacked bar chart from json data source
using grafana 8.3.3.
Im trying to create a stacked bar graph of what our computer cluster is doing, i cant access the backend db directly, so i have written a flask/json wrapper for it.
If it helps, im looking to display the data like this, We have “job_types” , example gpu_compute, cpu_compute, failed_compute.
Different projects then use one of the job_types. so im looking to from a project stack the totals of each per project.
right now i have the json data coming back like this:
      {'datapoints':[2599, 1640131443.0],
                 [5553, 1640132067.0]],
  'target': 'BB_gpu_compute-complete'},
  'target': 'BB_gpu_compute-failed'},
 {'datapoints':[4578, 1640131443.0],
  'target': 'BB_cpu_compute-complete'},
 {'datapoints':[65, 1640131443.0],
                 [115, 1640132067.0]],
  'target': 'BB_cpu_compute-failed'},
the value is in seconds.
i can see the data side by side if i use a gauged bar, but how do i need to format the data to do the stacked bar graph correctly.
Thanks
Kym
edit :: i release the time stamp was seconds not milli seconds and have fixed that
ok, i figured out how i can stack this data, using the columns/rows example here
Is there a way that i can define the colours for the stacked graph here aswell?
