I am using v7.2.1 (72a6c64532) of grafana in a EC2 machine. -
I have an Angular SPA wherein I am able to display panels from Grafana. Currently, the Angular SPA and Grafana has different login. I have a page in my SPA where I have to allow the user to log in to Grafana. What I want to do is that if the user is logged into the Angular SPA, the user should also be logged into Grafana. Is there any way to do that? -
This is the one approach I am trying i.e to use the Grafana login API(attached screenshot,
) to be integrated into my Angular SPA. So based on the response I will login the user in Angular SPA as well as Grafana. -
What happened?
I have tried to integrate this API but got a 404 error.
Is this the correct approach, or is there a better way?
I have tried integrating AWS Cognito, Okta using the sign-in widget, and also configuring okta in the Grafana server.
Is there a way to achieve SSO in my Angular SPA and Grafana?
