SQL builder, how to use any in?
Using on-premise grafana 11.5.1 running on rocky linux
I am trying to use the sql builder to make a where variable in(…) query.
I would expect this, or some other way of making a list of values to get me
hostname in (‘hosta’,‘hostb’) in the sql, but I have so far only gotten
hostname in (‘\‘hosta\’,\‘hostb\’’)
which is a perfectly logical thing to do, but how can I tell grafana that I have a list of possible values that I want into the sql?
I would highly discourage you from using Builder and instead use stored procedures or carve the query by hand
That kind of works, but gives a pretty funny sql
Although I guess postgres will optimize this to hostname in (‘hna1’,'hnb1). The bigger problem is that the WHERE clause in the builder is either OR or AND:
And to what you said about using hand written queries, That’s what I usually do, but when teaching my coworkers to make their own dashboards, it is easier for them to use the builder, and if I know them well, they will after a while start modifying the SQLs made by the builder.
