Hi I’m working on porting a Dashboard panel to a Grafana Scenes App.
When looking at the panel JSON to port it over to Grafana Scenes, there is this line:
"fieldConfig": {
"defaults": {
"custom": {
"lineWidth": 1,
"fillOpacity": 100,
"spanNulls": false
Which I have replaced with a Panelbuilders.statetimeline() with a
.setCustomFieldConfig('lineWidth', 1)
.setCustomFieldConfig('fillOpacity', 100)
.setCustomFieldConfig('spanNulls', false)
all of the above lines work, except for the last line, trying to set the spanNulls. Which results in the following error:
TS2345: Argument of type '"spanNulls"' is not assignable to parameter of type 'keyof FieldConfig'.
Has spanNulls keyword been removed or replaced with something else? A different keyword? Nothing?
If I switch the Panelbuilders line to PanelBuilders.timeseries(), the error disappears.
I have search online for hours, looking for a solution or hint to what the issue is and when the change occured, but I can find nothing. This page tells me that linegraphs support spanNulls, but nothing more.
Any insight to this issue would be appreciated.
