mguggi
1
Hallo,
I have a strange behavior and I don’t know if it is a problem with my LogQL query.
We get JSON log from our pods and when I display the stream in the log panel I get the expected result.
To be able to create a condition with fields in our JSON log we use the | json
parser on the log stream.
Unfortunately, as soon as we apply the parser, the sorting of our logs is no longer correct.
Here is a simple example of our query:
{namespace="app-system", pod=~".+appA-.+"} | json
Maybe someone has a tip for us how to get the correct sorting after applying the parser.
As additional information we currently use Loki 2.4.2 and Grafana 8.4.2.
Regards,
Manuel
The problem is still present in v 9.3.1
Using /loki/api/v1/query has a similar problem.
Granfa 9.4.7 and Loki 2.7.3
system
Closed
4
