Is it impossible to sort field log by Grafana Loki
Is it impossible to sort field logs by Grafana Loki? if yes please give me a example
For example: sorting with the “Insertime” or “SerialNumber” tag
Thanks.
Looks like it’s on the way: [new feature] logql:support sort and sort_desc by liguozhong · Pull Request #7989 · grafana/loki · GitHub
Not sure when it’ll make it into the release though.
Hi tonyswumac
Thank you for your response, it is impossible
  1. To set up the client side(Fluentbit) to send data step by step (order by datetime) when the device reconnection from the Internet
  2. instead of the Prometheus
Thanks,
Willie
