Immediately after restarting Influx, a message appears:
info Unauthorized {“log_id”: “10TtV0rl000”, “error”: “token required”}
The error occurs as soon as the Influx login attempt is made, i.e., when Influx is accessed in the browser.
Now also:
info Unauthorized {“log_id”: “10TvE5Zl000”, “error”: “session not found”}
Sorry, it seems these errors aren’t related to Telegraf. I stopped the Telegraf service and deleted the Telegraf bucket from Influx. The error still occurs. The connections between ioBroker, Influx, and Grafana are working correctly.
Nevertheless, I need to find the cause of the error.
Yes, I’ve already tested different time periods, including with various queries.
When I start the InfluxDB service, everything seems normal until I try to log in to InfluxDB via the browser. As soon as I try to log in, a message appears in the service window:
So probably one of the filters in the query doesn’t work properly (may be, its value for some reason is not transferred correctly from Grafana to InfluxDB).
As before, only the results are displayed without any filters.
However, I found something. In the view without all filters, there’s a reference to my still-active Raspberry Pi with the same system, but with current data. On this Windows 11 host, I have the old Raspberry Pi data. There’s no reference to the Raspberry Pi in the Telegraf.conf file.
