SOLVED: Enable Embedding In An Unraid Docker
Hello everyone,
I’m trying to bring in some system UI elements from Grafana into Homarr via iframes to build out a dashboard but nothing I copy/paste from Grafana seems to be working in Homarr. I was told that I need to enable embedding in Grafana but I have no idea on how to do this in an Unraid docker environment. Any guidance would be super helpful. Thanks <3
    Unraid Docker: Grafana v11.6.0 (d2fdff9ee4)
    Getting system stat UI elements like ‘CPU Load’ and "System Temp’ From Grafana into Homarr via iframe for UI elements in a dashboard.
    Copy Embed and Link options from Grafana’s UI element and paste that into Homarr’s iframe.
  • What happened?
    I get a frowny face URL logo in Homarr.
    For the UI Element to show up and work.
    http://192.168.0.19/goto/cJNnsB1Hg?orgId=1 is what I get when I copy the share link from Grafana. There is also an embed link as well but Homarr is asking for an http address.
    Nope.
    Many, I’ve been to over 15 sites but none of them tell you how to enable embedding for Grafana in an Unraid Docker. Why would you list embedding options in the UI if embedding is turned off? And why isn’t there a UI toggle for this vs editing an .ini file in 2025? Just make a settings tab with UI elements.
This got me up and running. Now I just need to find out how to make Homarr’s iframe to stop asking for login info. Maybe by making my board public?
