What Grafana version and what operating system are you using? Unraid 6.12.6
What are you trying to achieve? Access Grafana WebUI
How are you trying to achieve it? Going to my server address:3000
What happened? Firefox and Chrome give similar errors: The page isn’t redirecting properly
What did you expect to happen? the login page to load
Can you copy/paste the configuration(s) that you are having problems with? Typing in the webpage redirects forever
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly Pastebin of log: 060a8650 - 01/192.168.69.101/192.168.69.101/192.168.69.101/192.168.69.101/192.168.69.101/192.168.69.1
Did you follow any online instructions? If so, what is the URL? Unraid | Unraid Data Monitoring with Prometheus and Grafana
Hi @chrissware,
Thanks for opening this post.
The instructions and the docker image seems to be not maintained by us but instead by the Unraid community.
Therefore, suggestion would be to ask for help as only they can tell as what exactly need to be done to fix this.
I think this the correct link to their GitHub project.
I hope this helps.
