Hi all,
I’m trying to wrap my head around a particular template filter. What I need:
- Obtain list of ApiGateway endpoints (Resources) filtered by Apiname dimension.
Been messing around with a couple of things already but can’t seem to get this one right. What I’ve got so far is along the lines of:
dimension_values(eu-west-1,AWS/ApiGateway,Count,Resource,{"Name":"ApiName","Value":$api_gateway}) ($api_gateway is another variable).
When I try this, I get the following error:
Template variables could not be initialized: JSON.parse: unexpected character at line 1 column 27 of the JSON data
Would appreciate any pointer in the right direction (or an example of using values in filter and/or example of using variable in the filter).
Thanks
