Hi all,
I am trying to filter the following Cloudwatch query:
dimension_values($region, AWS/ELB, HealthyHostCount, LoadBalancerName)
What can I filter for? Where can I find a list of values? For example { "tag:SOME_TAG_LISTED_IN_AWS": [ "VALUE_OF_TAG" ] } does not seem to work. Also { "InstanceId": [ "ONE_OF_THE_ELB_INSTANCE_IDS_SHOWN_IN_AWS" ] } does not seem to work. Any ideas?
Best regards, macin
Hi macin,
The filters of dimension_values is a dimension filter, it is different from ec2_instance_attribute filter.
dimension filter
If your metric has multiple dimensions, you can use this filter to get dimension values dynamically. For example:
dimension_values($region, AWS/ELB, HealthyHostCount, LoadBalancerName ,{"AvailabilityZone": $az})
Ok I think I got it. And all available dimensions can be listed in my case for example using
aws cloudwatch list-metrics --metric-name "HealthyHostCount" --namespace "AWS/ELB"
