I’m having a problem with a new network device which is outputting the IF-MIB::ifXTable in a strange way.
When doing an snmpwalk on the ifName I can see the following output,
IF-MIB::ifName.3 = STRING: aa-0/1
IF-MIB::ifName.4 = STRING: aa-0/1.0
IF-MIB::ifName.9 = STRING: aa-0/2
IF-MIB::ifName.10 = STRING: aa-0/2.100
IF-MIB::ifName.11 = STRING: aa-0/3
IF-MIB::ifName.12 = STRING: aa-0/3.1
IF-MIB::ifName.13 = STRING: aa-0/3.2
IF-MIB::ifName.14 = STRING: aa-0/100
IF-MIB::ifName.15 = STRING: aa-0/100.0
But on the ifAlias I see this, (aaaaa is just an example)
IF-MIB::ifAlias.3 = STRING: aaaaa
IF-MIB::ifAlias.4 = STRING:
IF-MIB::ifAlias.9 = STRING: aaaaa
IF-MIB::ifAlias.10 = STRING:
IF-MIB::ifAlias.11 = STRING: aaaaa
IF-MIB::ifAlias.12 = STRING:
IF-MIB::ifAlias.13 = STRING:
IF-MIB::ifAlias.14 = STRING: aaaaa
IF-MIB::ifAlias.15 = STRING:
However the problem is that the data for the interface is always on the ones containing “.0”. If I filter this on the telegraf with tagpass for “aa-0/.” it would work and store data only from the correct interfaces, even I would loose the ifAlias.
Is there any possibility to mask the SNMP output, or maybe in the Query for the panel do some JOIN operation?
Thanks,
