Dear Community
I using Grafna with telegraf since a while and it is working good and we typically using $tag_abc for aliasing the metrics
But now I got to a point where we need to pull data via telefgraf like:
|docsRphyRpdIfPhysEntityDescr.168.245.221.255.130.240.1|Shelf|OctetString|
My problem is the aliasing of the device with this .1. Because the 168.245.221.255.130.240 without the .1 is my device name and the .1 is a sensor name.
How can I use the alias by tag because the name is pulled like:
Name/OID: cerRpdMacAddrName.168.245.221.255.130.240; Value (OctetString): BK_RPD
I hope my questions is clear as this is a bit hard to describe.
Best regards and thank you in advance
Hanno
