Snapshot.raintank.io Expired certificate
    v7.5.6 and v7.3.1 (deployed from grafana helm charts)
    Publishing the dashboard externally to snaphots dot raintank
    Through the Grafana UI (share/publish snapshot)
  • What happened?
    “Failed to create external snapshot” is being encountered when publishing the snapshot to snapshot dot raintank
    The dashboard to be published on snapshot dot raintank
    In the UI, “Failed to create external snapshot” is being encountered. Checking the grafana logs, it seems that it’s failing due to the certificate expiration of raintank:
t=2021-07-14T17:12:25+0000 lvl=eror msg=“Failed to create external snapshot” logger=context userId=0 orgId=1 uname= error=“Post “https://snapshots-origin.raintank.io/api/snapshots”: x509: certificate has expired or is not yet valid: current time 2021-07-14T17:12:25Z is after 2021-07-13T23:59:59Z”
