Hello team,
We want to delete the root policy which we are not able to do. We want to disable the smtp in defaults.ini file.
I disabled the whole smtp config and smtp enabled = false but both are not working. Restarting the grafana
Logs error:
Failed to start grafana. error: invalid email address for SMTP from_address config invalid email address for SMTP from_address config
Could you please help me?
Thanks in Advance.
Thanks & regards,
Bharath Kumar.
welcome to forum @chembakayalabharath
please share what you changed in the ini file?
#################################### SMTP / Emailing #####################
[smtp]
enabled = true
host = smtp-mail.outlook.com:587
user = $email
If the password contains # or ; you have to wrap it with triple quotes. Ex “”“#password;”“”
password = $PASSWORD
cert_file =
key_file =
skip_verify = true
from_address = $EMAIL
from_name = Grafana
ehlo_identity =
startTLS_policy =
[emails]
welcome_email_on_sign_up = false
templates_pattern = emails/*.html
This is the current current configuration I am using. I want to disable this config.
How to achieve this?
See the settings to use here
Is this an on prem grafana oss? Or a docker container instance?
It’s a docker container instance
