I’m currently struggeling with setting up the Slack notifier with S3 storage for images.
My config looks like this:
[external_image_storage.s3]
;bucket = grafana-stroage-scs
;region = us-east-2
;path =
;access_key = AAAAAAAAAAAA
;secret_key = AAAAAAAAAAAAAAAAAAAAAAAAAA
And the slack config see attach picture.
Logs:
t=2018-05-04T05:23:27+0000 lvl=info msg=“Executing slack notification” logger=alerting.notifier.slack ruleId=6 notification=“Mobile Lab Bot Radio”
t=2018-05-04T05:23:27+0000 lvl=info msg=“Executing slack notification” logger=alerting.notifier.slack ruleId=3 notification=“Mobile Lab Bot All Checks”
t=2018-05-04T05:23:27+0000 lvl=info msg=“Executing slack notification” logger=alerting.notifier.slack ruleId=6 notification=“Mobile Lab Bot All”
t=2018-05-04T05:23:27+0000 lvl=info msg=“Executing slack notification” logger=alerting.notifier.slack ruleId=6 notification=“Mobile Lab Bot All Checks”
t=2018-05-04T05:24:10+0000 lvl=info msg=“New state change” logger=alerting.resultHandler alertId=6 newState=ok prev state=alerting
t=2018-05-04T05:24:10+0000 lvl=info msg=Rendering logger=png-renderer path=“d-solo/qxpAAYMiz/checks?panelId=14”
t=2018-05-04T05:24:13+0000 lvl=info msg=uploaded logger=alerting.notifier url=
Do I miss something in the configuration?
Please read grafana documentation about comments in ini files which you have in your config!
Marcus
It’s still not sending the pictures config now looks like this:
region = us-east-2
;path =
Please don’t hijack topics like this.
Thanks
What does your Grafana server log say now when trying to generate image/upload it to s3? Turning on debugging in Grafana may help to get more information.
t=2018-05-04T12:52:40+0000 lvl=info msg=“New state change” logger=alerting.resultHandler alertId=5 newState=alerting prev state=ok
t=2018-05-04T12:52:40+0000 lvl=info msg=Rendering logger=png-renderer path=“d-solo/qxpAAYMiz/checks?panelId=13”
t=2018-05-04T12:52:41+0000 lvl=dbug msg="[phantom] Loading a web page: http://grafana.staged-by-discourse.com/d-solo/qxpAAYMiz/checks?panelId=13&render=1 status: success 30000" logger=png-renderer
t=2018-05-04T12:52:41+0000 lvl=dbug msg=“Image rendered” logger=png-renderer path=/var/lib/grafana/png/vmQGbcB36HgBRufB8S7m.png
t=2018-05-04T12:52:41+0000 lvl=info msg=uploaded logger=alerting.notifier url=
t=2018-05-04T12:52:41+0000 lvl=dbug msg=“Sending notification” logger=alerting.notifier type=slack id=3 isDefault=false
t=2018-05-04T12:52:41+0000 lvl=dbug msg=“Sending notification” logger=alerting.notifier type=slack id=4 isDefault=true
t=2018-05-04T12:52:41+0000 lvl=dbug msg=“Sending notification” logger=alerting.notifier type=slack id=1 isDefault=false
t=2018-05-04T12:52:41+0000 lvl=info msg=“Executing slack notification” logger=alerting.notifier.slack ruleId=5 notification=“Mobile Lab Bot Radio”
t=2018-05-04T12:52:41+0000 lvl=dbug msg=“Sending webhook” logger=notifications.webhook url=https://hooks.slack.com/services/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 http method=
t=2018-05-04T12:52:41+0000 lvl=info msg=“Executing slack notification” logger=alerting.notifier.slack ruleId=5 notification=“Mobile Lab Bot All Checks”
t=2018-05-04T12:52:41+0000 lvl=dbug msg=“Sending webhook” logger=notifications.webhook url=https://hooks.slack.com/services/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 http method=
t=2018-05-04T12:52:41+0000 lvl=info msg=“Executing slack notification” logger=alerting.notifier.slack ruleId=5 notification=“Mobile Lab Bot All”
t=2018-05-04T12:52:41+0000 lvl=dbug msg=“Sending webhook” logger=notifications.webhook url=https://hooks.slack.com/services/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 http method=
t=2018-05-04T12:52:42+0000 lvl=dbug msg=“Job Execution completed” logger=alerting.engine timeMs=55.468 alertId=5 name=“LTE - ICMP / HTTPS” firing=true attemptID=1
t=2018-05-04T12:52:44+0000 lvl=dbug msg=“Scheduling update” logger=alerting.scheduler ruleCount=6
t=2018-05-04T12:52:54+0000 lvl=dbug msg=“Scheduling update” logger=alerting.scheduler ruleCount=6
Seems like you’re still using local storage.
Have you configured the following?
[external_image_storage]
provider = s3
Hi. I have a similar issue with S3…
No matter what I do, I’m not able to upload images to S3
Here’s my config:
- GF_EXTERNAL_IMAGE_STORAGE_PROVIDER=s3
- GF_EXTERNAL_IMAGE_STORAGE_S3_BUCKET=https://xxx-xxx-xx-xxx-xx-xxxx.s3.amazonaws.com
- GF_EXTERNAL_IMAGE_STORAGE_S3_REGION=eu-west-1
- GF_EXTERNAL_IMAGE_STORAGE_S3_ACCESS_KEY=XXXX
- GF_EXTERNAL_IMAGE_STORAGE_S3_SECRET_KEY=XXXX
Here’s the log message:
msg=“Failed to upload alert panel image.” logger=alerting.notifier error=“InvalidBucketName: The specified bucket is not valid.\n\tstatus code: 400, request id: B318F7C37297CD69, host id: 3vyLxO9rjxTgcF4JvIqVECNB/kRzvipalfxkyxXIpudRmzZMu1uCSALiZd9+HpB2jQ126SlcaLY=”
The bucket name is correct and the region also. I event tried to use another url like:
https://s3-eu-west-1.amazonaws.com/xxx-xxx-xx-xxx-xx-xxxx
The bucket is public, the EC2 has the following permissions:
- s3:GetObject
- s3:ListBucket
- s3:PutObject
- s3:PutObjectAcl
What am I doing wrong?
Thanks
I think you’re looking for using bucket_url, see documentation.
Marcus
Thanks Marcus.
Replacing “bucket” with “bucker_url” did the trick.
