grafana version: v9.1.2
deployed with docker container, along with grafana image renderer docker container. -
I want to attach image in slack alert message. -
have tried to use local or aws s3 as external storage, but it doesn’t work. -
What happened?
I can see screenshot image created in grafana png directory, but not upload to s3, I can’t see image in slack alert message no matter use local or s3 as external storage. -
it shows image in slack alert message. -
[unified_alerting.screenshots]
capture = true
max_concurrent_screenshots = 5
concurrent_render_request_limit = 5
upload_external_image_storage = true
#################################### External image storage ##########################
[external_image_storage]
# Used for uploading images to public servers so they can be included in slack/email messages.
# you can choose between (s3, webdav, gcs, azure_blob, local)
provider = s3
bucket = xxx
region = xxx
access_key = xxx
secret_key = xxx
