10.0.2 -
I am trying to to simulate a dashboard that uses a timerange based on ‘now’ with an autorefresh period, but with static data. My dataset includes both tabular data and photos (which are displayed in a Dynamic Image Panel) so it is difficult to simulate the data
For example, the dashboard has the following in the URL
from=now-5m&to=now&refresh=5s
Ideally, I would like to set the fake ‘now’ time, and have an option to ‘play’ in real-time, or perhaps with a factor e.g 2x, 4x etc
- How are you trying to achieve it?
I have tried to generate a series of URLs, and also using semi-relative time-ranges- but can’t get it to work- the time range for the data I’m trying to simulate is fixed, but need to simulate it at various times e.g to present to others
thank you in advance
Andrew
