Signout option is not listing in side menu. I added “disable_signout_menu = false” in configuration.
build : Version 4.4.1 (commit: 6a9f8ca)
DB : Mysql ( Ver 14.14 Distrib 5.7.17)
Its under the profile menu
Torkel,
I am not finding any sign-out option. Here is the snapshots, Please correct me if I am wrong.
[auth]
Set to true to disable (hide) the login form, useful if you use OAuth
disable_login_form = false
Set to true to disable the signout link in the side menu. useful if you use auth.proxy
Regards,
Sudhi
Can anyone reply ???
the profile in the sidemenu? the top item in the sidemenu, hover over it
