Hi all,
I am trying to embed a dashboard to my webapp, which I am able to do by setting the
auth.anonymous = true
allow_embedding = true
But when the dashboard is displayed the Sign In option come at the left side bar menu, which when clicked takes me to login page, which I don’t want.
So I tried to disable the side bar menu disable_signout_menu = false
But this doesn’t help, then I tried by setting the
disable_login_form = true
signout_redirect_url = “dashboard URL”
Now, the in the login page the login fields are not coming but still it is going to the login page. In the URL I can see dashboard URL/login?redirect=%2Fd%2FrbmKvDDZk%2Ftelegraf-system-metrics
Can someone guide me what is the right way to disable the side bar menu fully or something similar.
TIA
I didn’t solve it but you can do it with by editing the CSS for sidebar as mentioned above but that’s not the right way because you’ll have to edit the CSS in every installation of Grafana. There’s another way of doing it, by using of a proxy server. Edit grafana.ini
[auth.proxy]
enabled = true
and
# URL to redirect the user to after sign out
signout_redirect_url=<PUT YOUR OWN HTML page, which you can close using javascript>
I’ve adopted the second approach using Apache server as reverse proxy server.
Hope, I am able to make you understand.
