Grafana v9.3.2
Ubuntu 20.04 -
When showing per-second values, I tend to use aggregateWindow to limit the number of data points, but then to get a per-second value using derivative one ends up with fractions and the values differ depending on v.windowPeriod due to the aggregation.
What I’d like, is to show the windowPeriod on the Dashboard (or graph), so that it is known what impact the windowPeriod had on the shown graph.
I tried using v.windowsPeriod as a variable and in a graph title, but that doesn’t work. And I’ve been unsuccessful in working out how to set a dashboard variable based on v.windowPeriod. -
What happened?
n/a -
n/a -
n/a -
no -
no
