Hi all,
I had a question about dashboard/metrics customization, I would like to request your assistance.
I would like to define a special dashboard to our L1 team, which contains status panels/measurement, which may appear only the problematic objects - show only the: “warning” and “critical” states of the current queries/metrics.
This approach would make it easier to focus on solving the problem as soon as possible.
My goal is:
Show only the orange and red marked query items, which exceeded the defined tresholds.
Other explanation:
I would like to create a layout such as nagstamon utility, which contains only filtered alerts/shows only the problematic objects based on monitored objects and tresholds.
Other importance:
There is a huge amount of dashboards and within these dashboard contains lot of different metrics which use a lot of space/pixels on the dashboard, there is no needed to show all of the green, healthy status on the monitoring display devices, instead of the affected elements requiring occupation.
I read the documentations, articles regarding this but unfortunately I didn’t find the exact solution for that scenario.
for example: JSON model | Grafana documentation
Our current Grafana version is: 8.2.2
Is there any chance/how can we apply?
Thank you in advance and sorry for my english!
Peter
