Grafana 9.5.2 packaged on Alpine Linux
- What are you trying to achieve?
I created a dashboard dedicated to temperature sensors. I have some time-range graphs panels (using the time series model) and some instant values panels (using the bag gauge model).
For the instant values panels (on the left on the picture), I wish that there was a way to display the current values, even when selecting a time range in the past.
- How are you trying to achieve it?
I did try to select “Type: Instant” in my query option.
- What happened?
The shown values are the last ones from the selected time range.
I expect the panel to show current values.
