Right now, we are shipping dashboards which are provisioned. But, in order to modify the dashboard you need to export with the changes and then re-import. Is there a way to update the provisioned dashboards in place. I’m using V5.4.3
Related topics
| Topic | Replies | Views | Activity | |
| Update all Dashboard | 1 | 726 | October 21, 2022 | |
| Provisioned dashboard updates between major versions | 2 | 146 | August 8, 2025 | |
| Can you update dashboard panels through HTTP requests? | 24 | 7630 | July 15, 2019 | |
| Provisioning dashboards in docker | 12 | 2547 | October 24, 2024 | |
| Is there a supported way to access the dashboard json and upload a changed version? | 7 | 2331 | May 12, 2024 |
