As grpc can multiplex multiple channels over a single http/2 connection, is it possible to share a single grpc client between VUs? It appears that currently each VU gets its own client instance each with its own tcp connection.
Hi @jimmymartin
Sorry for the long reply.
It should be possible with something like this:
import { Client } from 'k6/net/grpc';
const client = new Client();
export default () => {
if (__ITER == 0) {
client.connect(GRPC_ADDR, { plaintext: true });
// some grpc invokation
Let me know if that helps!
That’s basically what I do now which effectively creates a connection per VU. What I wanted to do was to have more VUs than connections.
Thanks, Jimmy
@jimmymartin I see now, sorry that I misunderstood your need;
Unfortunately, it’s not possible right now. The connection management currently delegates to the grpc dependency that we use. We previously received a proposal for connection per VUs sharing ([Experimental] Optional gRPC connection sharing among VUs by chrismoran-mica · Pull Request #31 · grafana/xk6-grpc · GitHub), but it hasn’t reached the merged state.
I hope that explains.
