Reconnect in VU
In self-written plugin “examplePlugin”, I have a connection to a server. this is a very slow operation.
I do this once at startup. Then I’ll reuse this connection. If there is a failure, I need to reconnect, but I don’t understand how to do this, since I can’t update “let conn” state from the “export function send_msg(){}” block.
I also couldn’t find this case in the documentation k6
import customPlugin from "k6/x/examplePlugin";
let conn = customPlugin.connect()
export function send_msg() {
 conn.send_msg()
Hi @chipartem :wave:
Welcome to the support forum :tada:
I think some background information to guide you to a solution might be necessary here :slight_smile:
Background
In the example you have posted, k6 treats the two existing JavaScript scopes in very different ways:
It happens in the “init context” and is executed a single time by each VU. Every time it is executed and a connection is instantiated, the connection object lives in a specific VU. That means if you run a test with 10 VUs, each VU will have a different connection object.
Thus,
// Each VU performs this step 👇 and ends up with its own
// dedicated instance of the connection.
  // As we are now in the VU context, this code uses the VU
  // connection object.
 conn.send_msg()
Although it might look like it, the conn object you define at the top is thus not a unique and shared object across all the VUs, and each of them, instead, instantiates its own copy independently.
We have documented the various lifecycle specificities and guarantees in the documentation: Test lifecycle | Grafana k6 documentation
I believe it might help you find solutions to your issue.
Solution space
Now, my understanding is that you would like to attempt reconnecting if/when the connection is lost.
If you’re fine with having one connection per VU as described above, making some check in the default function whether there’s a need to reconnect might help:
  if (!conn.connected) {
    conn.connect()
 conn.send_msg()
But depending on what you do in the rest of your load test, that could skew the results. It really depends.
Let me know if that’s helpful and if I can provide more information and support :bowing_man:
