Can I execute multiple gRPC requests concurrently within a single k6 script or simultaneously? or multiple grpc requests at a time?
How to efficiently execute multiple gRPC requests sequentially within a script using k6. Specifically, I aim to mimic the behavior of a typical login process followed by several subsequent requests, similar to what happens when logging in via a web browser.
To efficiently execute multiple gRPC requests sequentially in a script using k6, you can use the gRPC-Web library to communicate with a gRPC server over HTTP/1.1. This will allow you to simulate a typical login process, where an authentication request is first sent, and then other requests are made sequentially. Additionally, you can use k6’s parallel query capabilities to improve the performance of your test case.
