Sharing a Playlist
HI
I have Grafana Install with Home Assistant, and want to share my playlist, however
It seems the below is not as per my layout Version 7.2.0
Documentation states, and I cannot get it done
Any help will be appreciated
Share a playlist in a view mode
You can share a playlist by copying the link address on the view mode you prefer, and pasting the URL to your destination.
  1. From the Dashboards submenu, click Playlists .
  2. Next to the playlist you want to share, click Start playlist .
  3. In the dropdown, right click the view mode you prefer.
  4. Click Copy Link Address to copy the URL to your clipboard.
Example: The URL for the first playlist on the Grafana Play site in Kiosk mode will look like this:
Grafana.
5. Paste the URL to your destination.
Hello :wave: and welcome to the forum, @jbarkhuizen
what version of the documentation are you viewing? Do you have a link?
Also, version 7.2.0 is 13 months old. Is there anything keeping you from upgrading to the newest Grafana, 8.2.3?
Thanks
Home assistant installed that version
I also looked at various versions of the documentation
Not sure if I can upgrade the home assistant version yet, as it does not have upgrade as yet
hmmmm, sorry to say that I don’t know much about Home Assistant + Grafana. Perhaps they have a forum? Or I might search this forum for home assistant and hop on a relevant thread?
