11.1.3 -
Pass a group value to another panel -
Via setting variable and datalinks -
What happened?
Variable is not set -
Variable is set, target panel updates data based on the variable value -
No -
No
I have a Bar Chart based on SQL query. It groups data by “product” field and calculates count.
I have another panel (table view) - I’d like to click on a bar and show details in that panel for a selected “product”.
ChatGpt suggested to use Custom variable and a Datalink with a placeholder in a form of var-product=${__field.labels.product} but it does not work, variable is not set. I also tried different placeholders but with the same result. If I use __value.raw, variable is set correctly but to the Count value. Is it possible to achieve what I want? How can I set my variable to a group value- those ones that are painted on an image above
