I’ve noticed that while the Cloud API Token can be specified using an ENV variable, the Cloud Project ID value cannot… This seems to be an oversight.
Am I missing something?
Thanks in advance.
Thanks in advance.
HI @PaulMEdwards, Welcome to the community forum
The env option you are looking for is K6_CLOUD_PROJECT_ID. Did you not find it under Cloud tests from the CLI, it likely needs to be mentioned in more places, or are you saying it doesn’t work?
