We have the options in a config file 1scaledobject100metrics · GitHub
@$(K6_ENVS) TARGET_SCALABLEDOBJECTS=10 TARGET_METRICS=1 ./k6 run --out cloud tests/test-scaledobject.js --config configs/scaledobjects/1scaledobject100metrics.json
with the following error
Init [--------------------------------------] Starting outputs
default [--------------------------------------]
ERRO[0000] (403/E4) Missing Authorization token or trying to run an anonymous test
make: *** [execute-k6-scaledobjects] Error 255
Nevetheless when we have the same options within the test itself
it works properly.
We tried as well to follow the documentation and use the env variable K6_CLOUD_PROJECT_ID but using still
ext: {
loadimpact: {
with the same result ![]()
Maybe are we doing something wrong with the config file? As we would really like to have all the different workloads specified in the configs file as we do when running in local.
Thanks
