Set individual graph to fixed time frame
Hi Everyone,
i built a small grafana panel for visualising my PV system.
To show the power distribution over time for today i selected a time series graph, but can’t figure out to set the graph to only show the area with actual data or a set time, e.g. from 5 in the morning to 9 in the evening. The only way i come close is set some relative time from now, or the entire day (24h) in the query options which is a waste of space because the sun is not shining at night :grinning_face:
Can someone help me out how to configure my graph to only show a fixed time frame of the day? (My global Dashboard is set to show the last hour)
Grafana Version: v10.4.1
InfluxDB Version: v2.7.11
Thank you very much in advance :slight_smile:
Welcome @stratocaster . You can call me Les Paul :guitar:
Are you using Flux? If yes, the hourSelection function looks like it will work well for you.
Thanks for your answer :slight_smile:
I am using InfluxDB.
How can i use this hour selection in Grafana?
I am not an expert and only used the basic grafana editor / query builder so far :sweat_smile:
InfluxDB has 3 possible query languages. Which one are you using?
The hourSelection function is available in Flux only.
i am using the “regular” grafana InfluxDB editor mode which looks like this:
SELECT mean("value")  * -1
  FROM "smartmeter.1.value"
 WHERE $timeFilter
 GROUP BY time($__interval) fill(linear)
You are using InfluxQL.
Flux has hundreds of functions that are not available in InfluxQL (plus you can define / build your own). The hourSelection function would be perfect for your application, but unfortunately it’s only available in Flux.
Is there a way to achieve this with the “query options” function or otherwise in grafana itself?
Not that I am aware of.
You can achieve this by setting a custom time range for that specific panel. In the panel settings, go to Overrides and use the Time range option to define a fixed window, like 05:00 - 21:00 shades conroe tx. This way, your graph will only display data from that period without affecting the global dashboard settings.
Thanks for your answer, but unfortunately i can’t find an override for time range, only for time zone.
