Hi, I am trying to set an alert for a common (I believe) use case but I can’t seem to figure out.
Thanks for the help in advance.
Situation
- Data coming in every minute
- The data is number of transactions
- Datastore is InfluxDB
Alerting Idea
Number of transaction increased 100% in the last hour.
The following 2 kinds of windowing algorithm are both fine to me.
Algo 1 (fixed window)
Suppose there are total 100 transactions during 1:00 - 1:59
When there are >= 200 transactions at any time during 2:00 - 2:59.
I get alerted.
Algo 2 (sliding window)
Suppose it’s now 2:30pm
If number of transaction from 1:30pm to 2:30pm is 100% more than the number of transactions during 12:30 than 1:30pm
I get alerted
Not sure if “fixed/sliding window” are the correct terminology so please feel free to correct me.
I am also open to other suggestions.
What I tried
Query
SELECT sum(column) FROM database
WHERE $timeFilter and <some condition>
group by time(1h)
Alert Configuration
If I understand the documentation of influxdb and grafana correctly, this is not correct.
Let say current time is 1:30pm.
query(B, 1h, now) will return 2 data points.
12:00 | <number of transaction during 12:30 - 12:59>
13:00 | <number of transaction during 13:00 - 13:30>
Then based on this link, it simply compare the 2 data points which is not what I want.
So how do I achieve what I want? Thank you very much!
