I have a simple ServiceMonitor to scrape some services:
apiVersion: monitoring.coreos.com/v1
kind: ServiceMonitor
metadata:
namespace: monitoring
spec:
selector:
matchLabels:
krane/scrape-prom-metrics: "true"
namespaceSelector:
matchNames:
- krane
endpoints:
- port: web
path: /metrics
Alloy picks it up fine and also finds the target, but scraping fails because the endpoints are incorrect.
ts=2024-12-09T09:41:54.967799257Z level=debug msg="Scrape failed" component_path=/prometheus_operator_objects.feature component_id=prometheus.operator.servicemonitors.service_monitors scrape_pool=serviceMonitor/monitoring/krane-service-monitor/0 target=http://10.40.4.94:3000/metrics err="server returned HTTP status 404 Not Found"
It tries to scrape on 10.40.4.94 while it should be an address in the 10.44.x.x range. DNS resolution is correct if I run nslookup from a pod (in the same namespace).
I’m running the latest k8s-monitoring helm chart on GKE.
Does anybody have any idea what may cause this issue? Thanks!
