Service_name is always unknown_service
I setup a loki instance and started ingesting the logs using kube logging operator.
But it seems the service_name is always unknown_service.
I tried sending different fields like service_name, service.name and service, but nothing works it still shows the same unknown_service.
i restarted the loki cluster also but it didnt work.
example value of my service “monitoring______grafana__prometheus“
is this a known issue? or am i missing something?
your help is deeply appreciated,
thanks
Try to send desired service.name as resource (not log line) attribute.
got it, to set service as resource, i added the below in loki configuration:
labels:
  service: $.service
This resolved my issue and started grouping the logs properly.
@vipinjn24 @jangaraj , we are facing same unknown_service issue, Plugin used is fluent-plugin-grafana-loki. We tried below config in Loki chart and the other config on fluentd side, please advise:
Loki-chart-config:
limits_config:
discover_service_name:
- index
Fluentd-side config:
 <label>
            index $.index
            service_name $.index
            service $.index
          </label>
full fluentd loki-config:
      <label @REWRITTEN>
        <match \*\*>
          @type loki
          url "#{ENV\['LOKI_URL'\]}"
          ca_cert /secure/tls-certs/ca.crt
          line_format json
      \# FIX 1: Provide ONLY 'index' and 'valli'.
      \# Remove 'service_name' and 'service' so Loki's chart can discover 'index' automatically.
          <label>
            valli $.index
            index $.index
            service $.index
          </label>
      \# FIX 2: Do NOT include 'remove_keys index'.
      \# If you remove it here, Fluentd's buffer chunking breaks during evaluation.
      \# FIX 3: Keep $.index as the primary memory chunk routing key.
      <buffer $.index>
        @type memory
        flush_interval 1s
        retry_type periodic
        retry_forever false
        retry_wait 10s
        retry_max_times 2
        chunk_limit_size 8m
        total_limit_size 256MB
        overflow_action drop_oldest_chunk
        flush_thread_count 16
        queued_chunks_limit_size 32
        flush_at_shutdown true
      </buffer>
    </match>
  </label>
