Hello Grafana Community,
Pushing app logs from local grafana alloy to Grafana cloud.
Service name of the logs shows up as unknown_service in the logs ui.
How to fix this?
Thank you.
How to fix this?
Thank you.
I had this same problem. at first i used
stage.labels {
values = {
job = "my_job_name",
service_name = "my_job_name",
from this answer but it did not work for me. I then tried
stage.static_labels {
values = {
job = "nginx",
service_name = "nginx",
this seemed to do the trick, i was able to see nginx in grafana cloud explorer for loki logs.
Here is the full config
otelcol.auth.basic "grafana_auth" {
username = env("BASIC_AUTH_GRAFANA_USERNAME")
password = env("BASIC_AUTH_GRAFANA_PASSWORD")
local.file_match "nginx_logs" {
path_targets = [
{__path__ = "/var/log/nginx/*.log"},
loki.source.file "nginx_logfiles" {
targets = local.file_match.nginx_logs.targets
forward_to = [loki.process.labels.receiver]
loki.process "labels" {
forward_to = [loki.write.grafanacloud.receiver]
values = {
job = "nginx",
loki.write "grafanacloud" {
max_streams = 10
endpoint {
url = "https://logs-prod3.grafana.net/loki/api/v1/push"
batch_wait = "5s"
batch_size = "1MiB"
min_backoff_period = "1s"
basic_auth {
username = "xxxxxx"
password = env("BASIC_AUTH_GRAFANA_LOKI")
Awesome. Thank you very much for this solution
