Hello everyone!
When setting up a new server, I realized that the option to use grafana-agent is no longer available. Therefore, I set up alloy to send my server log files to loki in Grafana Cloud.
Everything is working fine and I can process the logs in Grafana Cloud. However, I am missing one feature that made it easier to handle the logs.
With grafana-agent, I was able to set tags for job and service_name. With alloy, I currently cannot find a solution and am looking for help.
I tried to use the loki.process as a pipeline step:
loki.process "add_labels" {
forward_to = [loki.write.grafana_cloud_loki.receiver]
stage.labels {
values = {
job = "my_job_name",
service_name = "my_job_name"
However, when restarting alloy, I get the following error message:
Failed to start Vendor-agnostic OpenTelemetry Collector distribution with programmable pipelines.
Any idea how I can add tags that I can then later use in Grafana as a selector statement (e.g., {job=“my_job_name”})?
Looking forward to your responses!
You are missing a , after the service_name line. Try this:
stage.labels {
values = {
service_name = "my_job_name",
Thank you very much for your message, Tony! I tried adding the , after the service_name line. Unfortunately, I still get the same error after restarting the alloy service.
Here is the full output of the status command:
× alloy.service - Vendor-agnostic OpenTelemetry Collector distribution with programmable pipelines
Loaded: loaded (/lib/systemd/system/alloy.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Mon 2024-07-08 19:40:41 CEST; 28s ago
Docs: https://grafana.com/docs/alloy
Process: 53294 ExecStart=/usr/bin/alloy run $CUSTOM_ARGS --storage.path=/var/lib/alloy/data $CONFIG_FILE (code=exited, status=1/FAILURE)
Main PID: 53294 (code=exited, status=1/FAILURE)
Jul 08 19:40:41 SERVER systemd[1]: alloy.service: Scheduled restart job, restart counter is at 5.
Jul 08 19:40:41 SERVER systemd[1]: Stopped Vendor-agnostic OpenTelemetry Collector distribution with programmable pipelines.
Jul 08 19:40:41 SERVER systemd[1]: alloy.service: Start request repeated too quickly.
Jul 08 19:40:41 SERVER systemd[1]: alloy.service: Failed with result 'exit-code'.
Jul 08 19:40:41 SERVER systemd[1]: Failed to start Vendor-agnostic OpenTelemetry Collector distribution with programmable pipelines.
Thank you very much! Your hint with checking the journal provided the solution. I accidentally forgot to add the receiver attribute as part of forward_to.
Here is the whole info in case someone else has a similar problem. For me, it is solved now.
Config file:
local.file_match "local_files" {
path_targets = [{"__path__" = "/home/user/myapp/logs/*.log*"}]
sync_period = "60s"
loki.source.file "log_scrape" {
targets = local.file_match.local_files.targets
//forward_to = [loki.write.grafana_cloud_loki.receiver]
forward_to = [loki.process.add_labels]
tail_from_end = true
stage.labels {
values = {
job = "myjobname",
service_name = "myservicename",
loki.write "grafana_cloud_loki" {
endpoint {
url = "XXX"
basic_auth {
username = "XXX"
password = "XXX"
Journal with command: sudo journalctl -u alloy.service
Error: /etc/alloy/config.alloy:58:18: loki.process.add_labels should be capsule, got object
57 | //forward_to = [loki.write.grafana_cloud_loki.receiver]
58 | forward_to = [loki.process.add_labels]
59 | tail_from_end = true
Thanks again for your help!
Long time since this was posted, but this should fix that error.
forward_to = [loki.process.add_labels.receiver]
You have to send it to that block’s receiver, not the block itself.
