Server Sizing required for Grafana
Hello Techies, @mattttt @anon34853223
We are trying to implement grafana and integrate with our prometheus instances for Dashboarding purpose.
I would like understand the server Sizing (RHEL 7) required for grafana implementation.
Basically we will integrate with Prometheus instances whcih will scrape 6000 samples per second… Can some one suggest the below
OS --> Linux RHEL 7 is decided
RAM requried --> ?
CPU --> ?
Disk space requrird --> ?
@torkel
Just adding you as well for suggestions
Hi @ravikumariq,
Please see similar questions here, here and here.
If you’re going to use Grafana Alerting you may need to add some CPU and memory.
