Sequentially run scenarios
I have three tests which I want to run sequentially, after the one is completely done. I am using scenarios and I got it working, but as of now my tests are being run simultaneously.
I have been looking for quite a while now, without success. I get the feeling that I am completely overlooking the answer for this.
My code:
import runLoginTest from './loginTest.js'
import runGetCustomizationTest from './get-customizationTest.js'
import runGetCustomizationsTest from './get-customizationsTest.js'
export const options = {
  scenarios: {
    login_test: {
      executor: 'constant-vus',
      vus: 5,
      duration: '10s',
      gracefulStop: '0s',
      exec: 'loginTest',
    get_customization_test: {
      vus: 5,
      duration: '10s',
      gracefulStop: '0s',
      exec: 'getCustomizationTest',
    get_customizations_test: {
      vus: 5,
      duration: '10s',
      gracefulStop: '0s',
      exec: 'getCustomizationsTest',
export function loginTest () {
  runLoginTest()
export function getCustomizationTest () {
  runGetCustomizationTest()
export function getCustomizationsTest () {
  runGetCustomizationsTest()
Thank you for reading and for the help in advance.
See the startTime option in Scenarios
In your case, it’d go somewhat like this:
  scenarios: {
    login_test: {
      vus: 5,
      duration: '10s',
      gracefulStop: '0s',
      exec: 'loginTest',
      vus: 5,
      duration: '10s',
      gracefulStop: '0s',
      startTime: '10s',  // duration + gracefulStop of the above
      vus: 5,
      duration: '10s',
      gracefulStop: '0s',
      startTime: '20s',  // duration + gracefulStop of the above
That does the job, thanks! Turns out I’ve been overlooking it all along.
How can I run scenarios sequentially if I don’t want to configure a duration, but execute a fixed number of iterations for each scenario and then run the next one?
@jacob, unfortunately there’s no way to do that yet. We plan to eventually implement a startAfter property to allow you to chain scenarios like that, as described in Test suites / execute multiple scripts with k6 · Issue #1342 · grafana/k6 · GitHub. However, as you can see from the comments I made there regarding the implementation complexity, I can’t promise it will be any time soon.
For now, the best you can do is set a good approximate maxDuration of your iteration-based scenarios and calculating their startTime based on the maxDuration + gracefulStop of all preceding scenarios. Or, do things the old way, as separate k6 scripts you execute sequentially with a bash script or something like that.
thanks for the speedy reply @ned! i’ll find away around it for now.
Hi @nedyalko,
I also have same requirement as @jacob . I see the issue that you shared is still open. Are you aware of any progress being made for this since it’s been over 3 years since this thread was posted?
@jacob Curious if you find any workaround that you can share here?
Still need the possibility to run test sequentially (wait for a test to end before running the next one). I want to run multiple k6 browser tests, I can’t predict the time it takes.
Thanks
