Run tests sequentially
Hey
I tried some different approaches, but I want to executed one test after another and not parallel.
I tried with group and without groups
export default function () {
group('Sign in', () => {
    test__1()
group('Sign out', () => {
    test__2();
I could archive this only with scenarios and add a startTime. Is there a possibility to run tests sequentially or was is this a specific purpose that this doesn’t work?
Thanks
Hi there, welcome to the forum :slight_smile:
As you’ve found out there’s not an easy way to accomplish this yet. Multiple scenarios with startTime is relevant, but not really helpful for running them sequentially.
You can follow issue #1342 for updates about this. One workaround you could try is to run multiple k6 run commands from a shell script, though that’s not that ideal. There’s no ETA for this issue yet, but it’s high on our priority list and we’ll consider it for upcoming releases.
Thanks @imiric
Then we wait until the next release
