How to run scenarios in sequence?
Hello everyone
In the documentation Scenarios it is described that you can run scenarios sequentially. Default is parallel. But how to change this behaviour?
With kind regards
Joel
@Lamera you can add startTime option to the scenario you want to run sequentially add the time that the first scenario will take to complete
