v8.4.1 hosted on Kubernetes -
Send a single alert for each alert (state change). -
Added a template, calledSingleAlertContent:
{{ define "SingleAlertContent" }}
Value: {{ or .ValueString "[no value]" }}
Labels:
{{ range .Labels.SortedPairs }}
{{ .Name }}: {{ .Value }}
{{ end }}
{{ if gt (len .Annotations) 0 }}
Annotations:
{{ range .Annotations.SortedPairs }}
{{ end }}
{{ end }}
{{ if gt (len .DashboardURL ) 0 }}
Go to dashboard: {{ .DashboardURL }}
{{ end }}
{{ if gt (len .PanelURL) 0 }}
Panel: {{ .PanelURL }}
{{ end }}
{{ end }}
Added another template, called SingleAlertTitle:
{{ define "SingleAlertTitle" }}
[{{ .Status | toUpper }}] {{ .Labels.alertname }} {{ if gt (len .Alerts.Firing) 0 }}firing:{{ .Alerts.Firing | len }}{{ end }}
{{ end }}
Used the templates in my default, Slack, contact point:
- Title: {{ template “SingleAlertTitle” . }}
- Text Body: {{ template “SingleAlertContent” . }}
Fired a test notification from within the contact point.
What happened?
A Slack message was sent with only the state[FIRING](from the title) in it.
This is what the same test notification looks like, without the templates:
Get a Slack message that contains the details for the single alert.
The actual goal is to get a single message for each alert, like we did before in Grafana v7.
The templates in the snippets above, or just an attempt to achieve this. -
