How to get alertname in notification title
    Grafana 8.1.2 with NGAlert enabled
    I want to see alert name in notifications titles using my own template
    I’ve created template:
{{ define "template_title" }}
[{{.Status}}] {{ .Labels.alertname }}
{{ end }}
and set it as templated title of the Slack message.
I get this code here - Notification templating | Grafana documentation
  • What happened?
    Alert message in Slack is empty with just status
    I expect to get normal alert message
No
Can you screenshot your full alert config? If you are using Grafana managed alerts with a classic condition, templating will not work.
You must use a multi-dimensional rule.
Hi Matt!
I don’t know how it works, but now I use template based on default one and get only title.
[{{ .Status | toUpper }}: {{ if eq .Status "firing" }}{{ .Alerts.Firing | len }}{{ else if eq .Status "resolved" }}{{.Alerts.Resolved | len }}{{ end }}] {{ .GroupLabels.SortedPairs.Values | join " " }}
{{ end }}
And yes, I use multi-dimensional rules everywhere.
I can’t explain why {{ .Labels.alertname }} isn’t working
I’m aware this is old, but I could find no other information on the fix. The documentation is severely lacking, but fortunately I found the answer in the source code.
Use {{ .CommonLabels.alertname }}
Hope this helps someone.
@arrudick This is a great find. Thank you for posting. Can you paste a screenshot of a working example of this?
Thank you so much for this!!! I have lost the best part of the afternoon trying to get the alertname on the title of a MS teams alert and this has done the trick. Would have saved me a lot of time if this was made clear in the documentation! Thanks again.
Apologies @grant2 I did not see your reply.
I did according to the example above but in my case it didn’t work. Does anyone have an idea why it didn’t work, I’m using grafana version 9.2.5
