Please avoid posting in the Grafana parent category. Whenever possible choose a subcategory.
Hi All,
We are looking to create some custom template to send the notification in good format. We able to get some sort of data there but not able to present in defined format. We are looking to split the lines in template but it looks like taking all the contents as string and wrapping as per text.
Please find below the screen shot
Regards,
Shashi
THANK YOU!!
~ the grafana team
We are using the below template to make the alert message.
{{ define “myalert” }}
[{{.Status}}] - {{ .Labels.alertname }},
{{ with .ValueString }}
Metric Values : {{- . | reReplaceAll \[\s “” | reReplaceAll \],\s “\n” | reReplaceAll \] “” | reReplaceAll var='[A-Z0-9a-z]+'\s “” | reReplaceAll labels=\{[A-Za-z0-9_\-\=\s\.:,]+\}\s “\n” | reReplaceAll metric='(.*)' " $1 " | reReplaceAll value=([0-9\.]+) “($1),” }}
{{ end }}
Labels:
{{ range .Labels.SortedPairs }}
{{ .Name }}: {{ .Value }},
{{ end }}
{{ if gt (len .Annotations) 0 }}
Annotations:
{{ range .Annotations.SortedPairs }}
{{ end }}
{{ end }}
{{ if gt (len .SilenceURL ) 0 }}
Silence alert: {{ .SilenceURL }},
{{ end }}
{{ if gt (len .DashboardURL ) 0 }}
Go to dashboard: {{ .DashboardURL }}.
{{ end }}
{{ end }}
{{ define “mymessage” }}
{{ if gt (len .Alerts.Firing) 0 }}
{{ len .Alerts.Firing }} firing:
{{ range .Alerts.Firing }} {{ template “myalert” .}} {{ end }}
{{ end }}
{{ if gt (len .Alerts.Resolved) 0 }}
{{ len .Alerts.Resolved }} resolved:
{{ range .Alerts.Resolved }} {{ template “myalert” .}} {{ end }}
{{ end }}
{{ end }}
Regards,
Shashi
Check out this post - it’s for slack, but has steps to get the query response labels into your message template.
Edited this solution to add the most common answers in this thread in one place, including template functions and labels with dots in the name - read through to the end for those
welcome to the community @baileyheit1 !
This is a really common question and I’m still learning how to access the values out of the alert query too. I hope this is a helpful example - I tried to make it very detailed for the benefit of other community users, even though I can tell you already know how to do s…
