8.1.4
I have recently updated from version 7 and don’t remember this issue before so it’s possible its a very recent bug. -
Changing a variable i.e. $hostname should update a query when it is changed. (It randomly stops after first few changes) -
I have setup a variable. I have both generated the variables through a select and hardcoded them. If reference them in the grafana query using $hostname. Then change them on the dashboard. -
What happened?
Initial it loads with the correct information. You can change hostname and sometimes it updates the dashboard but eventually changing it subsequent times will stop one or more of the tiles from updating.
Using the Query inspector you can see that it will stop propagating through at a certain point in time. -
I expect changing the variable to always update the queries related to it. -
Not sure what I can send that is useful. It is a very simple setup. -
No errors. -
I could not find any instructions around this problem.
Anyone got a suggestion as you what to try next on this one?
Could you provide more information about the query
- which data source are you using?
- what does the query look like?
- how do you know that it is not updating? Are you looking at the network tab in Chrome to see that no new queries are being triggered? Or does the data in the panel not match the $hostname value?
The data source is postgreSQL 12.
Multiple queries are failing to update. It is random as to how many fail. An example query that is not working is :
SELECT
$__unixEpochGroupAlias(nanoseconds/1000000000, $__interval),
sum(abs(quantity)) OVER (ORDER BY nanoseconds) AS lots
FROM fill
WHERE
$__unixEpochNanoFilter(nanoseconds)
and host=’$Hostname’
ORDER BY 1
The data in the panel does not match the $hostname value for some of the panels.
