About a week or two ago I started seeing 4x of every dimension in the metric I am monitoring. I haven’t changed the panel, and the JSON for the panel looks fine.
I can provide the JSON if it helps
Have exactly the same issue, I use the CloudWatch data source.
Did not find a way how to fix that.
Same, this is the Cloudwatch data source. I’ve verified that the source metrics in Cloudwatch don’t have this issue.
Fixed in 7.3.1:
Any idea when Grafana Cloud will be updated?
