How do I list all the pin_err_** codes using query in Grafana loki?
when a query unable to grouo it by error code.
any help is appreciated
Some example log would be helpful.
2023-03-06 10:38:34
4a98ddd4f690eaa9839e268483ca4461db232fb046a63d0046b02eab6cbcceee
flush_thread_1
kt999cc15w005
pod-754d556d56-wp4pt
ff019aa7-02b6-404b-a495-3eb4d0a57f49
{“log”:“E Mon Mar 6 10:38:34 2023 pod pod:1344396 pod_utils.c(155):6405 2:wsm-tomcat-64f47d9678-b59jh:WebService3715:1678095514:15674::::\n\n\tpod pod->FM input flist: opcode=Ppod_OP_ECE_POST_COMMIT, flags=0x0, errno=PIN_ERR_UNKNOWN_EXCEPTION:66\n\n# number of field entries allocated 20, used 1\n\n0 PIN_FLD_POID POID [0] 0.0.9.8 /publish 0 0\n”,“stream”:“stderr”,“time”:“2023-03-06T09:38:34.764133053Z”}
2023-03-06 10:38:34
flush_thread_1
kt999cc15w005
{“log”:“E Mon Mar 6 10:37:01 2023 pod pod:1344150 fm_utils_publish.c:755 2:wsm-tomcat-64f47d9678-b59jh:WebServic3715:1678095420:22719::::\n\n\tPpod_OP_ECE_POST_COMMIT returned an error\n\n\t<location=PIN_ERRLOC_EM:18 class=UNKNOWN:0 errno=PIN_ERR_UNKNOWN_EXCEPTION:66>\n\n\t<field num=0:0,0 recid=0 reserved=0 reserved2=0 time(sec:usec)=1678095:421275>\n\n\t<facility=0 msg_id=0 version=0>\n\n341918165 32 /oms/virtual_time/shared/pin_virtual_time_file\n”,“stream”:“stderr”,“time”:“2023-03-06T09:37:01.276536541Z”}
2023-03-06 10:38:29
dc2f8ff9af063e946579be080dabf2b42ceb25269b8447bc97e51df6d9235d7a
flush_thread_5
kt999cc15w004
pod-754d556d56-z7lh4
f2203d34-8a30-4651-9243-fa97987600bb
{“log”:“E Mon Mar 6 10:38:29 2023 pod pod:1339177 pod_utils.c(155):6405 2:wsm-tomcat-64f47d9678-b59jh:WebService3715:1678095508:15633::::\n\n\tpod pod->FM input flist: opcode=Ppod_OP_ECE_POST_COMMIT, flags=0x0, errno=PIN_ERR_UNKNOWN_EXCEPTION:66\n\n# number of field entries allocated 20, used 1\n\n0 PIN_FLD_POID POID [0] 0.0.9.8 /publish 0 0\n”,“stream”:“stderr”,“time”:“2023-03-06T09:38:29.349802685Z”}
Your step should be:
- Parse with JSON.
- Extract the
logfield. - Parse with logfmt or pattern.
- Extract the
errnofield. - Aggregate.
Example:
sum by (errno) (
count_over_time(
{your_label=your_label_value}
| JSON
| line_format "{{.log}}"
| logfmt
[5m]
If logfmt doean’t work, write your own pattern to match with.
Thanks
But something Im missing here what it can be-
sum by(ERRNO) (rate({namespace=~“abc-app”, container=~“xxx”} |= PIN_ERR_ | json | line_format {{.log}} | logfmt [5m]))
What do you get if you simply run your query without aggregation? Like what does this give you?
I get good formatted log string
something like below-
What Im looking for is just errno= PIN_ERR_xxxx to be summed
i tried adding label filter but it would give me only one error number and I dont want to hard code any error code
Blockquote
“abc-app”, container=~“xxx”} |= PIN_ERR_ | json | line_format {{.log}} | logfmt | errno=PIN_ERR_BAD_VALUE:46>
Log labels
E
Mar
ccc_OP_BILL_MAKE_BILL
Wed
_05_00_22
_2023
2_pje_pin_bill_accts_2279318__437257408_110_1678248010_60199_root_0_0_0_1__
_8
_facility 0
_field
_location PIN_ERRLOC_CM:3
an
application oc-xx-helm-chart
class PIN_ERRCLASS_SYSTEM_INDETERMINATE:2
cm
cm_1627019
cm_child_c_141__5131
component xx-yyy
container xxx
container_id xxxxxxxd9235xxx
env pcrf15-t
errno PIN_ERR_BAD_VALUE:46>
error
fluentd_thread flush_thread_3
host anvcnbcbc
Not entirely sure what you are looking for. Are you looking for a specific error number? Or are you looking to just extract the number only?
I’m looking to find all the unique error codes and then show the count of their occurrence in chart
Like pin_err_ bad_value count 47
Pin_err_ xxx count 48
Etc etc
any other great ideas to unblock me?
